19 years agoelf2flash and bootloader questions
I'm trying (so far in vain) to get RedBoot to run from flash. The ROMRAM startup version of RedBoot works fine when loaded into RAM via JTAG, but the ROM startup version of RedBoot doesn't r...
19 years ago> I can find no detailed documentation on either elf2flash or the mysterious
> external bootloader which appears to be available only as an srec file. I forgot ... you can review the bootloader code -- look in: $SOPC_KIT_NIOS2\components\altera_nios2\sdk\src\boot_loader_sources Regards, --Scott
