19 years agoelf2flash and bootloader questions
I'm trying (so far in vain) to get RedBoot to run from flash. The ROMRAM startup version of RedBoot works fine when loaded into RAM via JTAG, but the ROM startup version of RedBoot doesn't r...
19 years agoFirstly, thanks for the resonse.
>> I can find no detailed documentation on either elf2flash or >> the mysterious external bootloader which appears to be >> available only as an srec file. > >You need to read the "Nios II Software Developer’s >Handbook." I have. The copy I have is document number NII5V2-6.0. >> * What exactly does "elf2flash" do? > >See the handbook for details ... What details? There's exactly one mention of elf2flash in the handbook with a single phrase saying that it"converts an.elf executable file to a .flash file for programming into
flash memory". >but basically what it says: it converts the elf to a flash >file. Very simply: it creates a record for each loadable >section, throws in the bootloader if necessary, and outputs the >srec for the flash programmer. Thanks, I had deduced that, but I was looking for exact descriptions of what each parameter does, where the bootloader is "thrown in", etc. >> * Why can't "objcopy" be used like all other normal eCos targets? > >It can -- just run it from the command line. Then why was elf2flash written? Just for obsfucation value? >> * What is the external bootloader .srec file for? > >Read chapter 4 in the handbook ... the section "Memory Usage." I did. And I just searched it again: the string "bootloader" doesn't appear even once in the handbook. Chapter 4 is about using the HIOS2 HAL system library. I'm not using the HAL libarary, I'm using eCos. Am I reading the wrong handbook? >> * Why would a ROM-resident bootloader like RedBoot require >> a second bootloader? > >It doesn't -- you can use objcopy and bin2flash (if you want to >use the flash programmer). If it's not required, why is program_flash adding it to the
srec file?
