13 years agoelf size too large for hello world application
Hi All, i am new to Altera's Nios-II, so as usual started with hello world template i am able to build it but the elf size is comes about 677274 bytes after applying all the optimizations (acc...
13 years agoThnx for the information
but i dont have actual hardware to test anyways is there any way to exclude jdi and sopc somebody in a archive post talked about changing configuration from debug to release to shrink footprint. where's that configuration setting ? --- Quote Start --- The elf file includes a lot of information used for jtag debugging. The size of the file itself is not an indication of the actual memory requirements of your program. Infact the report states your code fits in 1320bytes (plus the space required for stack and heap), so you shouldn't have any problem with loading your application into onchip ram. However, afaik jdi and sopc files are normally not included into elf file: probably you have switched on some option in project settings. --- Quote End ---
