13 years agoelf size too large for hello world application
Hi All, i am new to Altera's Nios-II, so as usual started with hello world template i am able to build it but the elf size is comes about 677274 bytes after applying all the optimizations (acc...
13 years agoThe 677k size is definitely too large, even with stdio printf and without optimization.
I confirm you it should fit in 64k: I checked a similar hello world elf I have here. Try this shell command: nios2-elf-size <filename>.elf It will briefly report the size of your memory sections
