12 years agoEDS 14.0 tool dtc
So i'm trying to edit my socfpga.dtb file bij using the socfpga.dts file. But with EDS 13.1 you could do "dtc -I dts -O dtb -o socfpga.dtb socfpga.dts". Only with EDS 14.0 the command doesn't work...
11 years ago --- Quote Start --- Question - Using Linux for hosting the tools. Has anyone added any custom IP's? I started with the GSRD for the Altera Cyclone V Dev Kit. We added a custom IP and a PLL. I generate a *.dts file that I add the driver information but the PLL isn't in the *.dts because in Quartus14.1/Qsys there is no base address because it is like the other clocks. So, how do I get the PLL recognized properly for my .dtb file? --- Quote End --- SOLVED -- Using 14.1 tools and a suggestion - I took the GSRD *.dtb file used the sopc2dts (NOT IN THE COMMAND SHELL) and made a *.dts file. I added my custom IP and the pll as a fixed clock - like "clk_0" is in the GSRD into that "clocks" section. pll_0: pll_0 { compatible = "fixed-clock";# clock-cells = <0>; clock-frequency = <1843198> /* 1.843198 MHz PUT YOUR VALUE HERE */ clock-output-names = "pll_0_outclk0"; }; //end pll_0 (pll_0) THEN I GENERATED A *.dtb file using the 14.1 "dtc" # ] ./dtc -I dts -O dtb -o socfpga.dtb socfpga-AddedMyIPs.dts THIS BOOTS so now I need to try my device driver, etc
