12 years agoEDS 14.0 tool dtc
So i'm trying to edit my socfpga.dtb file bij using the socfpga.dts file. But with EDS 13.1 you could do "dtc -I dts -O dtb -o socfpga.dtb socfpga.dts". Only with EDS 14.0 the command doesn't work...
12 years agoI tried again tonight -- this is the command line i used with the SoCKit -- but it reported some errors. In the end the kernel hung up . Based on some comments I read on the rocketboards list, others have had the problem but I haven't had time to track it down.
(14.0 tool chain) sopc2dts --input soc_system.sopcinfo -t dtb --output socfpga.dtb --board soc_system_board_info.xml --board hps_clock_info.xml
