20 years agoEdge Detecttion Using SOPOC Builder
I'm been going over the Edge detection usinf SPOC Builder Application note 377 and i can't seem to find or don;t have some of the files. The document is at, http://www.altera.com/literature/an/an377.pdf (http://www.altera.com/literature/an/an377.pdf) The thing is i need the file with the Avalon interface which according to the document should be in <install path>\CycloneII_DSP_Kit-v.1.0.0\Examples\HW\ReferenceDesigns\Tool_Flow\Simulink and the file is called sopc_edge_detector.mdl does anyone have this file or know whre i can get hold of it. Thank very much and i hope to hear from you soon1 Reply
I am having the same problem; have you already solved it? Do you know where could I get those files Thank you very much
