21 years agoeCOS Library Creation
Hello
I am new to eCOS, can somebody help me how to create a eCOS library. I am following the eCos 2.0 for Nios II document that I got after installing the eCOS for Nios II. I am not able to create a eCOS library as mentioned in section 6.1. The following command can't be executed in Nios SDK Shell. > nios2configtool --ptf=$sopc_kit_nios2/examples/verilog/niosII_cyclone_1c20/standard/std_1c20.ptf --cpu=cpu Pls, let us know how to use the nios2configtool. Thanks Narasimhan.R India2 Replies
<div class='quotetop'>QUOTE </div>
--- Quote Start --- nios2configtool --ptf=$sopc_kit_nios2/examples/verilog/niosII_cyclone_1c20/standard/std_1c20.ptf --cpu=cpu[/b] --- Quote End --- It's my worked command (bash point in examples dirrectory): > nios2configtool --ptf=./verilog/niosII_cyclone_1c20/standard/std_1c20.ptf --cpu=cpu Need remove symbol '$', and add './' - Altera_Forum
Hello Major
It worked. Thanks Rgds Narasimhan.R
