21 years agoeCos from epcs
Hi all Does anybody know if eCos supports botting up from epcs instead of the on board flash device on ALtera's developement board (the 1c20 board) ? Looking at the templates tab under the ...
21 years agoI've had a quick look at this, and I've found that a simple work around is to just add the __reset symbol to your elf file yourself. You can do this by adding the following to the linker options:
-Wl,--defsym,__reset=0x2100000 where 0x2100000 is the base address of your epcs device. Linker flags are set under "Global build options" in configtool. Having done that, the program_flash script will work as expected.
