21 years agoeCos from epcs
Hi all Does anybody know if eCos supports botting up from epcs instead of the on board flash device on ALtera's developement board (the 1c20 board) ? Looking at the templates tab under the ...
21 years agoI'm suprised that the command line didn't show up. Are you sure that you ticked the right option?
In any case, you will find the rule being run in the file generated_app.mk which is in the "system_description" directory of your system library project. That may solve this puzzle for you.
