21 years agoeCos for Nios II 5.0 now available
eCos for Nios II 5.0 is now available for download from the downloads section of this forum.
21 years agoThis is the code in the .entry section, which is placed by the linker script at the reset address of the processor - which in your case would be a location in the EPCS device, not the SDRAM. Have you modified the linker script as well?
In any case, you can either just jump to the _start location instead, or if you really do need the code in the .entry section, you can remove the conditional compilation of this section (i.e. the use of CYG_HAL_STARTUP_ROM) in vectors.S.
