20 years agoeCOS, Cyclone I/II, and Sockets
Hello All, I am a rank newbie to both the NIOS II, and eCOS; and I was hoping that I could get some advice/pointers on how to get an IP over RF (PHY) Modem/Router working on the NIOS II wit...
20 years agoHi vava,
> Where can I obtain the PPP library for eCOS, I didn’t find it C:\altera\kits\nios2\components\ecos\ecos-current\packages\net\ppp\current\src > How can it be built into my eCOS library Enable CYGPKG_PPP ... look for PPP support in Build->Packages > would it be better to use eCOS or uCLinux? That depends. If you already have eCos up-and-running ... you might not want to switch horses with only 4 weeks left. Although, having a shell (and telnetd) are certainly handy ;-) > Is there a port uCLinux for the NIOS II Cyclone I/II FPGA’s? Yes ... but the port is for Nios-II ... if Nios-II can be implemented on the device, you can use uClinux. Regards, --Scott
