20 years agoeCos and the Nios IDE 6.0
I am having tremendous problems using the Nios IDE to perform debugging on an eCos based Nios 2 design. Most of the breakpoints I put in do not stop the processor (unless I put them in from the "dis...
20 years agoOK. Sorry, but I don't have any more ideas to suggest! I find that I can't set breakpoints in the ecos source code at all. I can only step into the ecos source code form map app using the debugger which is really tedious. If you find a good solution then please post it to the forum.
Mike
