RAlex4
6 years agoEclipse showing error message
I am new to NIOS II EDS. I am trying to generate a calculato using the nios system. I tried to build and run my code. First, I got an error with Target connection. I tried to refresh the connection,...
AnandRaj_S_Intel
6 years agoHi Reba,
Your consol message is showing build error, Error on bsp folder clean the project & bsp and regenerate the bsp & build project and check.
If you face same issue try to recreate the eclipse project with the correct .sopcinfo file.
Anand
- RAlex46 years ago
Hello Anand,
Yes, that fixed the error. Thank you for the support.
Reba
