RAlex4
6 years agoEclipse showing error message
I am new to NIOS II EDS. I am trying to generate a calculato using the nios system. I tried to build and run my code. First, I got an error with Target connection. I tried to refresh the connection,...
AnandRaj_S_Intel
6 years agoHi Reba,
Provide a console message log.
Also, share information about your design, Development kit & Tool version & edition used.
If possible share your project.
Anand
RAlex4
6 years ago**** Build of configuration Nios II for project nios_calculator ****
make all
3 [main] sh 15604 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
the public mailing list [email protected]
1 [main] sh 1204 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
1 [main] echo 5560 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
Info: Building ../nios_calculator_bsp/
make --no-print-directory -C ../nios_calculator_bsp/
2 [main] pwd 16248 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
2 [main] sh 6960 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
1 [main] echo 13232 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
Makefile not up to date.
1 [main] echo 8056 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
../../niosii_system.sopcinfo has been modified since the BSP was generated.
1 [main] echo 12672 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
1 [main] echo 1332 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
Generate the BSP to update the Makefile, and then build again.
1 [main] echo 10620 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
1 [main] echo 8176 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
To generate from Eclipse:
1 [main] sh 15364 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
1. Right-click the BSP project.
1 [main] sh 10468 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
2. In the Nios II Menu, click Generate BSP.
1 [main] echo 8324 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
1 [main] echo 10708 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
To generate from the command line:
1 [main] sh 3900 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
nios2-bsp-generate-files --settings=<settings file> --bsp-dir=<target bsp files directory>
1 [main] echo 9788 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
1 [main] sh 10636 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to
make[1]: *** [public.mk] Error 1
make: *** [../nios_calculator_bsp/-recurs-make-lib] Error 2
**** Build Finished ****Hello Anand,
I am using the DE2-115 development kit, and lite version of Quartus II 14.0 to build the system. I have attached the C code for the calculator
