Eclipse not starting from inside quartus 19.1
In 19.1 and above you must install the NIOS II SBT after getting the Quartus installed.
Please see the link below:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/why-does-the-nios--ii-not-installed-after-full-installation-of-t.html
For 18.1 and 17.1 it should be working fine, Can you share any error you are facing while invoking the NIOS II SBT?
- GHelb6 years ago
If you read the original message: the SBT was already installed.
Your telling me to do something that I have already done.
I have shared the error(s) - when I try to start nios2-eclipse I get the message "Segmentation Violation - Core Dumped". That is the only message.
I seems that the testing was done using WSL (Windows Subsystem for Linux). This is not a valid test of a Linux application.
