21 years agoEclipse 3.0
Has anyone tried upgrading to Eclipse3.0/CDT2.0? It looks like the latest version addresses some serious issues like the 100% cpu time problems with javaw.exe - and not being able to open exte...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- you are going out on a limb using something not tested.[/b] --- Quote End --- The branch I'm on is about to collapse anyway! The bug causing 100% cpu usage basically renders the IDE unusable. Every time I want to compile some code, I must first...[list][*]Exit Eclipse [*]Use task manager to kill javaw.exe process [*]Use task manager to kill eclipse.exe process, if still running [*]Restart Eclipse! [/list]As you can see, not much fun. I'm sure this problem relates to a bug in Eclipse CDT 1.2.1, but I can't upgrade that without upgrading the whole thing to Eclipse 3.0, and as you say, that's not trivial - there seem to be changes/fixes required to the altera eclipse plugins. That I was even considering trying to use 3.0 should give you a measure of my desperation... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif - Roddy
