12 years agoEclipse 13.1 Modified libary is not re-linked
I think this happened when we went to 13.1, but difficult to be sure... I have a library project that is referenced from my application project. If i change some function in the library and re-build the library, the .a file updates. However, when i build the application project it doesn't seem to notice the change. This means that the old functionality is still there. To ensure that the change was made, i need to do a clean of the application project and then build. This is two manual steps and is very time consuming. I have the eclipse project references set up and the library and directory is in the Nios Makefile. Do you have a solution for this? MelNo RepliesBe the first to reply
