Eclipse - Serial Flash Controller II IP-Core - Micron MT25QL256 - The initial process goes wrong
- 3 years ago
Hi
The "Serial Flash Controller II" IP does not support external flash such as Micron but dropdown selection got micron, there are some register memory map mismatch issue if using micron. please use Generic QUAD SPI Controller II.
Actually engineering team plating for new ip for this. may be it's available in next version.
reference :
Hi
reference :
Hi Harish,
Thank you for searching for the solution!
BTW, why not use the IP-Core "Generic Flash Serial Interface"?
