Amir3
3 years agoEclipse - Serial Flash Controller II IP-Core - Micron MT25QL256 - The initial process goes wrong
Hey,
At Nios environment, I am using the "Serial Flash Controller II Intel FPGA IP" in order to communicate with the Micron MT25QL256 memory device. This device is connected to the Active-Serial s...
- 3 years ago
Hi
The "Serial Flash Controller II" IP does not support external flash such as Micron but dropdown selection got micron, there are some register memory map mismatch issue if using micron. please use Generic QUAD SPI Controller II.
Actually engineering team plating for new ip for this. may be it's available in next version.
reference :
hareesh
3 years agoHi,
In Eclipse, the IP-Core driver addresses the ID register in Byte #1 instead of Byte #3. This mismatch prevents the driver from finishing its initialization process
can you please give more information about that line. i didn't get it.
