JLemo4's avatar
JLemo4
7 years ago
Eclipse - Error Creating Project (Access is Denied)
I am trying to create a simple template hello world nios application for a 19.1 Quartus pro project. First, the SBT shortcuts were installed by default, but not the underlying files for eclipse. So, none of the shortcuts work after installation. I followed the instructions I found online to install Eclipse for 19.1 (why is it missing in this latest Quartus version...??). and now I can run the SBT, but when I try to create a hello world project and bsp - it fails. It seems to make the bsp project fine, but then fails on the hello world app saying "Error Creating Project c:\mypath\Makefile (Access is denied).
I checked that I have full ownership of the working directory, and I am the admin on the Win 10 machine. I saw 2 other posts with the same exact thing - but no resolution. I did notice if I go to a nios 2 command shell and look at file permissions, it appears all files and directories Eclipse itself is creating, doesn't have rwx for the file owner or the all users (---rwx---) - when I force them with chmod -R a+rwx - still no luck. I am running the SBT (eclipse-nios2.exe) as administrator as well. As another data point, using the SBT for 18.1 works fine creating template projects with the same .sopcinfo file.
Any help would be appreciated!
  • Ahmed_H_Intel1's avatar
    Ahmed_H_Intel1
    Thanks for your trial and confirmation, I filled an internal issue to report this issue.
    Please continue with the working build, I will let you know once we have update on this. I really appreciate your patience and help.
    Ahmed_H_Intel1
    Some how the 19.1 and 19.2 version left the admin permission for some files. you can grab control by (Right click the folder>>Properties>>Security Tab>>Select users(exJohn)>>Press Edit>> Check the "Full control" box>> OK) .
  • Jens's avatar
    Jens
    we had the same problem using Quartus Prime Standard 18.1 Build 646. After downgrading to 18.1 Build 625 this issue disappeared.
    Jens
    Ahmed_H_Intel1
    Thanks for helping Intel to improve the Quartus tool. I really appreciate your help.
