15 years agoe2fsck slows boot
Hi, I'm working with the Cyclone II Dev board and a Compact Flash (ext3 formatted - journalling). We use ext3 because I am writing data to a file on the CF and when we lose power and we reboo...
15 years agoAll,
Thanks for all the comments. @Daixiwen and @mschnell - I do use the Industrial CF that @Daixiwen mentions. I have used it sucessfully in an embedded flight data recorder (multiple copies) with a Cirrus Processor. I used uClinux and did a e2fsck on every boot and the sytem came up in say, 90 seconds. VERY RELIABLE. WE HAVE NEVER HAD A PROBLEM WITH THESE CFs losing data. I also do the fsync on this and we have found that we only lose 200 msecs worth of data (we can compare with other recorders on the A/C). Now they want data at boot time too. So, we are trying to tackle this with the Nios II on a Cyclone II (we are trying to stay away from the Stratix because of price). Our prototype PCB that should be here soon has enough memory for a 32 second boot (we thought that would do it - we did not think we'd get such BIG numbers for checking the CF). With the Cyclone II Dev Board we've got a simulated data rate and I really think we have the VHDL, my driver and the user space code optimized. I've looked at "top" while we are running and 52% of the time is spent doing i/o. BACK TO THE "journalling" : At boot I'm doing a: e2fsck -pv /dev/sda1 If the CF is clean I get a 9 second boot. If I run it for a short period of time I get 16-20 second boots. If I run it for longer periods - my boot time once was 2 minutes 45 seconds !! SHOULD I TRY ANY tune2fs settings ?? SHOULD I check the disk differently at boot ? I tried not checking and the system hangs. THANKS IN ADVANCE
