15 years agoe2fsck slows boot
Hi, I'm working with the Cyclone II Dev board and a Compact Flash (ext3 formatted - journalling). We use ext3 because I am writing data to a file on the CF and when we lose power and we reboo...
15 years agoHmmm.
Do you really believe their wording means that you can switch off power directly after writing a sector and you can be sure that this sector and all other data is safe ? It obviously is not possible to do internal wear leveling without consuming any power and time. So if you switch off power shortly after a write, the device will need to react in some way, provided it can live for a short time on internal capacitators. Maybe it can abort the wear leveling in some decent state. -Michael
