21 years agoDynamic Bus Sizing on Avalon Bus
Hi all,
To access a 8-Bit Port on a DSP (TMS320 / HPI8) I've implemented an 'Interface to User Logic' as Avalon memory slave. This module has 8-Data-Bits, 11 Addr-Bits, WRn, RDn, and CSn, all shared on Avalon except CSn. Because of its internal 16-Bit structure and 8-Bit interface a double access is necessary to read/write data via this interface while A[0] specifies upper or lower byte. So 'Dynamic Bus Sizing' should be the perfect solution. With a 16-bit-write to the port all seems to be ok: two WRn strobes with A0 changing from 0 to 1. But in a 16-Bit-read command four read cycles (RDn) are generated, reading a whole 32-Bit word on succeeding addresses. Disassembling the appropriate code shows 'ldhu r2,0(r2)' is used (once) in this context. Because the DSP-Interface has auto increment when reading its port, additional strobes increment internal address counter. My question is: How can I ensure that a 16-bit read on a 8-bit location produces only two read cycles on Avalon bus? Has anybody an answer? Mike ----------------------------------- Quartus: 4.1 Build 208 SP2 NIOS II SOPC Builder: 4.1 Build 208 Windows XP Pro3 Replies
Mike,
It's true that reads and writes are handled differently wrt dynamic bus sizing. Your writes are working as expected because the Nios2 asserts 2 of the 4 byteenable signals on the data master, and the dynamic bus sizing state machine takes this into account. On reads, the dynamic bus sizing logic ignores byteenable, and assumes full-width reads, as you've observed. Here are two solutions: 1) Define the port as an 8-bit native slave (Avalon Register Slave in the interface to user logic). Two accesses will be required for each 16-bit read or write, but at least it should work. 2) Create a bridge component with a 16-bit native aligned slave and a 16-bit master. The bridge simply passes access across to the actual 8-bit slave. Because its master is 16-bit data width, the dynamic bus circuitry will work as you need. This approach is a bit more work but would yield higher performance. If you want to go this way, I recommend using the new "Create New Component" feature in SOPC Builder in QII4.2 (it supports components with multiple slaves/masters, unlike the interface to user logic which is restricted to a single master or slave). - Altera_Forum
Thanks for your response
<div class='quotetop'>QUOTE </div> --- Quote Start --- 1) Define the port as an 8-bit native slave (Avalon Register Slave in the interface to user logic). Two accesses will be required for each 16-bit read or write, but at least it should work.[/b] --- Quote End --- I've tried this but a register slave doesn't use dynamic bus sizing and makes one single access everytime. So to access a 16-bit word through a 8-bit port needs software overhead. <div class='quotetop'>QUOTE </div> --- Quote Start --- 2) Create a bridge component with a 16-bit native aligned slave and a 16-bit master. [/b] --- Quote End --- I realized now that I have to add a special interface anyhow because the DSPs are using big endian coding internally. Mike - Altera_Forum
Hi MiR,
I'm using HPI-16 as well ... w/custom interface. There is an opencores project: http://www.opencores.org/projects.cgi/web/wb2hpi (http://www.opencores.org/projects.cgi/web/wb2hpi) that you might find interesting. Regards, --Scott
