21 years agoDude, where are my JTAG pins
Hi, To my surprise, after creating a Nios-II system using SOPC builder and specifying 'level1' for the 'JTAG debug module', I see no JTAG pins on the symbol when I return to the...
16 years agoI am trying to access the Jtag pins in my RTL simulation also. Not having much luck :(.
I want to test the system level design at the top level with no software interaction in a 'real' system (as part of an automated self-checking VHDL testbench). (And as a software independant check.) [I've had a look at the PLI and this does not support the SOPC Jtag UART which is what the design I am looking at is using.] I am thinking that over the Jtag pins is the best option. Using the System Console to exercise the programmed chip is fine, but to exercise the RTL design what am I supposed to do without access to the Jtag pins? I feel a little lost :(.... [Also; can somebody provide me with a URL to where the Altera communications over the Jtag port to the NiosII is decribed (serial message and format sent in through TDI for read/write/etc).]
