21 years agoDude, where are my JTAG pins
Hi, To my surprise, after creating a Nios-II system using SOPC builder and specifying 'level1' for the 'JTAG debug module', I see no JTAG pins on the symbol when I return to the...
21 years agoHi Roland,
> I see no JTAG pins on the symbol when I return to the .bdf. Correct ... you won't see the JTAG ports on your system module. Same goes for the epcs controller, for example. > ... a non-visible connection is made between my Nios-II module > and the JTAG pins on the Cyclone chip. Correct ... basically ... the connection between the Cyclone JTAG and the Nios-II JTAG debug module doesn't appear in your system module symbol. Regards, --Scott
