Dual Slave UserLogic
Hi all,
Can anyone point me in the right direction of an example SOPC peripheral with multiple slave ports? I basically want to have a standard slave register port for setting up a continuous stream and another slave port that supports streaming so a DMA controller can continuously pull data out of it. I can't see any obvious documentation on this and unless I've missed something simple in SOPC I can't see how to add the second port as a separate unit, alternatively what changes are required in the hdl to support this or won't the userlogic plugin support different modules? Thanks in advance...5 Replies
I suppose I'll have to dig into the ptf file manually.... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
I just used two ports. A setup port and data port. I write to the setup port to control (set up) the peripheral and then the data streams into the data port. Never got streaming dma perfect, only 99.99% perfect. Perfect data stream didn't come until I used a fifo and dma'd those contents on AlmostFull.
I'm about to give streaming dma another try going out to my USB chip though. Good Luck, Ken - Altera_Forum
What I did in NiosI was to make two seperate slaves (say 1 and 2). Slave 1 was implemented as a route through for the processor signals. Slave 2 had extra inputs for the processor signals from slave1.
I know it is not the most beatifull solution, but it works perfect. And no hassle with ptf files needed. - Altera_Forum
Well I just got stuck in with the Class.ptf for the peripheral and it seems to be okay.
So one port with control and status signals on it and then a second slave that supports streaming transfers (with a 1k fifo inside it for buffering), seems to be okay but i'll know more soon if it can handle my streaming rates. It'll be interesting to see if there is any advantage to be gained by using dynamic bus sizing on it since my streamed output is only 12 bits, so assuming I promote this to 16 bits, I'm wondering how the dma will handle multi word transfers, I'm hoping it will improve throughput by doing a double read and then transfering the data. Thanks anyways, ...Darren - Altera_Forum
Altera is working on an enhanced "New Component" builder which will help you to intantiate multi-port (Slave and/or master).
I saw it and was very impressed ! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Should be available in WW48 with Quartus 4.2. Maga
