16 years agoDual access block ram access from nios and custom vhdl
First, Id like to say I'm new to using Altera FPGA's so sorry if this is very simple. I have implemented a dual access block ram in SOPC. One side goes to the nios-II core so i can read and write fro...
16 years agoyou need an Avalon-Memory Mapped master to connect to the dual port RAM MM slave. take a look at custom components in SOPC Builder to make your HDL into a SOPC component, or using the component editor to make a simple MM-master that gives you access to the MM signals outside of SOPC Builder. here's a place to start:
http://www.altera.com/literature/hb/qts/qts_qii54005.pdf
