20 years agoDSR not called
Dear Forum readers I've been scrathing my head for some time over this. I have a custom board that gives me a periodic interrupt. I've written a ISR- DSR handler pair and they wo...
20 years ago --- Quote Start --- originally posted by jskjoet@Nov 9 2005, 11:56 AM the problem has been located.
stepping through the assembler code i noticed that the index into the hal_interrupt_data is calculated and stored in r15.
then a call to the isr takes place and upon return r15 is used again for finding the dsr and calling the interrupt_end function.
if the isr uses r15 without restoring it this scenario will obviously crash in many flavours http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
in the broken code r15 is used by the compiler and not restored which is perfectly legal according to the register usage table 7-2 in nios ii processor reference handbook.
depending on the kind of c code you write in the isr you can have r15 corrupted or not.
i've just modified the vector.s code to use r16 instead of r15 pushing it onto the stack etc and that did the trick.
In my humble opinion this seems to be a major bug in the Nios port of ecos. [/b] Looking forward to having your opinions. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10881) --- Quote End --- [/b] --- Quote End --- jskjoet, Thank you for isolating this. We are getting the ecos package for Nios II 5.1 together now and this is one item being looked at.
