11 years agoDS-5 Baremetal:Failed to load image
Hi, I'm running a baremetal application to write and read a byte of data into the DDR memory. The attached image shows the configuration of the DS-5 debugger being used. The error log is a...
AJama4
7 years agoAfter loading the preloader, manually or using the debugger script, you need to turn on semihosting by adding the following line;
set semihosting enabled true
