11 years agoDS-5 Baremetal:Failed to load image
Hi, I'm running a baremetal application to write and read a byte of data into the DDR memory. The attached image shows the configuration of the DS-5 debugger being used. The error log is a...
8 years agohello moggiozzi
I can't understand that what kind of change I have to make in spl code. FYI I want to test DDR3 - HPS interface using a bare metal debugging. "OR 3) Initialisation scripts used precompiled version of u-boot-spl. You have to build your own version of SPL and replace it in project direcoty (or adjust makefile). In my case I add little changes to spl code that he completed after hardware initialization."
