20 years agoDP83847 and NiosII
Good Morning, I purchased a (f****d) development board with a National DP83847 Ethernet Phy chip. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif Is it possible t...
19 years agoIf you have the DBC2C20 board than their homepage states: "Several Ethernet based reference designs, a NIOSII getting started tutorial, and a standard reference designs are delivered with the board."
If you would like to conect a LAN91C111 chip to your custom board than: - check the schematic and Quartus project for one of the Altera Nios II Development Kits (the one that uses the same Altera chip) - check Quartus II projects for the board for example the Full Featured The schematic and projects can be found in your Quartus and Nios installation directory under: C:\altera\kits\nios2_60\documents C:\altera\kits\nios2_60\examples\vhdl IzI
