14 years agoDownloading ELF Process failed
PC:
Altera 10.0sp1, Nios IDE10.0sp1; Win7 32bit ultimate Chinese edition ---------------------------------------------------------------- when i use on chip memory,every goes well.but when i use sdram controller,try many times,the same error. Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x00000000: verified Initializing CPU cache (if present) OK Downloading 01000000 ( 0%) Downloading 01003D58 (63%) Downloaded 16KB in 0.2s (80.0KB/s) Verifying 01000000 ( 0%) Verify failed between address 0x1000000 and 0x1002723 Leaving target processor paused ------------------------------------- the log: Downloading ELF Process failed,An exception stack trace is not available. Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0, CPU master group not set. CPU architecture type not set. ... --------------------------------- what should i do?thank you !
