15 years agoDownloading ELF Process failed
PC: Altera 10.0sp1, Nios IDE10.0sp1; Win7 32bit ultimate Chinese edition ---------------------------------------------------------------- when i use on chip memory,every goes well.but when i ...
9 years agoHello Rupok,
Can you share your solution ? I've the similar problem and can't resolve it since 3 days. I've tried 2 different projects - one with On-Chip memory, other with SDRAM. The result is the same in both cases - downloading begins ... then fails suddenly. Here is the message in console: Using cable "DE-SoC [USB-1]", device 2, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused Thanks in advance. Pavel.
