15 years agoDownloading ELF Process failed
PC:
Altera 10.0sp1, Nios IDE10.0sp1; Win7 32bit ultimate Chinese edition ---------------------------------------------------------------- when i use on chip memory,every goes well.but when i use sdram controller,try many times,the same error. Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x00000000: verified Initializing CPU cache (if present) OK Downloading 01000000 ( 0%) Downloading 01003D58 (63%) Downloaded 16KB in 0.2s (80.0KB/s) Verifying 01000000 ( 0%) Verify failed between address 0x1000000 and 0x1002723 Leaving target processor paused ------------------------------------- the log: Downloading ELF Process failed,An exception stack trace is not available. Failed Executing: [nios2-download, '--cable=USB-Blaster on localhost [USB-0]', --device=1, --instance=0, CPU master group not set. CPU architecture type not set. ... --------------------------------- what should i do?thank you !24 Replies
Hi mikedsouze
Thanks for your support. I have solved the problem. Thanks Rupok - Altera_Forum
Hello Rupok,
Can you share your solution ? I've the similar problem and can't resolve it since 3 days. I've tried 2 different projects - one with On-Chip memory, other with SDRAM. The result is the same in both cases - downloading begins ... then fails suddenly. Here is the message in console: Using cable "DE-SoC [USB-1]", device 2, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused Thanks in advance. Pavel. - Altera_Forum
check the resets and clock signals to the core CPU. I'd say there is a good chance either that it's not receiving any clock or that it's stuck in reset. For example with the wrong polarity defined on the reset input.
- JMuri1
I found out that I had not moved one of the keys on my MAX 10 board up to the correct position. By moving key 9 to the up position Nios II was able to upload the ELF file without a problem.
/James
