15 years agoDownloading ELF Process failed
PC: Altera 10.0sp1, Nios IDE10.0sp1; Win7 32bit ultimate Chinese edition ---------------------------------------------------------------- when i use on chip memory,every goes well.but when i ...
10 years agoYour Qsys system looks fine.
However, I noticed that the CLOCK_50 pin assignment is missing from the Nios_led.qsf. You will need to set the pin to the correct clock pin on CYCLONE IV E. Also you can try to run simulation as well.
