15 years agoDownloading ELF Process failed
PC: Altera 10.0sp1, Nios IDE10.0sp1; Win7 32bit ultimate Chinese edition ---------------------------------------------------------------- when i use on chip memory,every goes well.but when i ...
10 years agoI received same massage,“Launching New Configuration has encountered a problem”, "Downloading ELF Process failed" and I solved by check Pin Assignment . In Qsys SDRAM name SDRAM but pin name is DE1 is DRAM. I changed and OK. I hope it help you.
