15 years agoDownloading ELF Process failed
PC: Altera 10.0sp1, Nios IDE10.0sp1; Win7 32bit ultimate Chinese edition ---------------------------------------------------------------- when i use on chip memory,every goes well.but when i ...
13 years agoYeah. In new console there is no error message is showing. I copied the error when its running. Actually the real problem is my nios system target connections couldn't get the correct name of nios cpu and the jtag uart cable. Following is the error i see in nios console.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x00000008: verified Leaving target processor paused
