Yevpator
2 years agoDownloading ELF Process Fail
I have been facing the following problem since I started working with NIOS-II (Arria-ii and Max10). From time to time, suddenly, it's impossible to connect to the target with Eclipse (version 18.1). E...
aikeu
2 years agoHi Yevpator,
Glad that you have resolve the issue on your side.
Anyway after checking with the team, there is no much intermittent failure in the downloading elf process.
Mostly is failure due to hardware IP/BSP setting as below:
- JTAG Timing Constraint (https://www.intel.com/content/www/us/en/docs/programmable/683081/22-2/jtag-signals.html)
- System clock frequency = 4x JTAG frequency (https://www.intel.com/content/www/us/en/docs/programmable/683836/current/jtag-target-connection.html)
Aik Eu
