Yevpator
2 years agoDownloading ELF Process Fail
I have been facing the following problem since I started working with NIOS-II (Arria-ii and Max10). From time to time, suddenly, it's impossible to connect to the target with Eclipse (version 18.1). E...
aikeu
2 years ago- Yevpator2 years ago
Thank you for your comment.
The clock is ok - as I wrote before I manage to program or load image file with the Programmer or even with NIOS shell (tried that today). If I had issue with the clock, I wouldn't be able to load sof file with the Altera programmer, but it works good, the problem happens only while I am debugging with Eclipse.
