Yevpator
2 years agoDownloading ELF Process Fail
I have been facing the following problem since I started working with NIOS-II (Arria-ii and Max10). From time to time, suddenly, it's impossible to connect to the target with Eclipse (version 18.1). E...
aikeu
2 years agoHi Yevpator,
Is it a sometimes download fail problem regarding your issue?
Can you check if this is related to your code size changes especially every time a download is being performed?
Aik Eu
- Yevpator2 years ago
Dear Aik Eu,
No it is not related with the code size. Sometimes i succeed to enter the debug mode, suddenly the debug session fails or i exit and next time I try to load the same elf file without changing its size it does not work.
