14 years agoDownloading ELF file onto target NIOS processor Failed
Hello, When I build and download my Hello World application using the 'Run Configurations' GUI menu in Eclipse, I get a 'verify failed' error. Anyone know what this indicates and how I can resolv...
14 years agoBTW the correct way to do this is to set reset vector to a non-volatile memory, say ext_flast and the rest to sd_ram.
It should work in any case - whether you run from a flash or dowloading sof and run sw in the nios tools.
