14 years agoDownloading ELF file onto target NIOS processor Failed
Hello, When I build and download my Hello World application using the 'Run Configurations' GUI menu in Eclipse, I get a 'verify failed' error. Anyone know what this indicates and how I can resolv...
14 years agoTry to run it from an onchip memory, i presume you are running it from some external memory...
(if it works with onchip it is for sure a timing problem, take a look on how to configure the PLL degrees of an external mem)
