16 years agoDownloaded tarball and like to build linux for a custom design with nommu
I am new here and seeking some help to work with a custom design with no mmu. A I downloaded the tarball nios2-linux-20100621.tar and started working. fter 2 days of trials using nioswiki, ...
16 years agoThanks a lot tklauser. That helped.
Now I am able to build a linux image either way. I was thinking i do not need to use test-nios2 branch with 20090929 tarball. Once check out test-nios2, I need to use ptf file. Adding a board and nios2 header file only works with nios2mmu branch, is that correct? I am not able to build the toolchain_build due to error(c-parser.c not found). Is this required (any updates?). I have installed the binary tool chain.
