20 years agoDownload Nios II Processor 6.0 Update
I'm running the SOPC Builder for the standard design and it informs me that there is an update for the Nios II processor. I have 5.0 installed, and it says there is version 6.0 available. I can...
20 years agoUnfortunately, you cannot download the CPU component individually. Currently the CPU component and the software development tools are bundled together. Also, to install the Nios II v6.0 design suite you must first install Quartus II v6.0.
To your question about licensing: the "evaluation" edition CPU becomes a "full" edition if you have a valid license file. The only difference between "eval" and "full" is the lack of the MicroC/OS-II source code in the evaluation edition. If you're curious whether or not you should install the 6.0 release, you can find out all of the changes in the nios ii eds v6.0 release notes (http://www.altera.com/literature/rn/rn_nios2eds_60.pdf).
