11 years agoDownload Elf Process failed
Hi, i am working on cyclone V soc (5csxfc6d6f31c8) and using nios II as processor. i have generated sof and sopcinfo and also programmed the device successfully. But after configuring the nios and...
11 years ago --- Quote Start --- Could post a screenshot of the timing analysis report? --- Quote End --- I am attaching the following snapshots - 1.give no errors in Timequest timing analyzer ang shows it successful https://www.alteraforum.com/forum/attachment.php?attachmentid=10150 2. setup and hold summary of Timequest timing analyzer - https://www.alteraforum.com/forum/attachment.php?attachmentid=10151 https://www.alteraforum.com/forum/attachment.php?attachmentid=10152 I can see slack issue in the clock source in above. Is this the cause for the issue?? And if it is how to get over it? Thanks again !!
