11 years agoDownload Elf Process failed
Hi, i am working on cyclone V soc (5csxfc6d6f31c8) and using nios II as processor. i have generated sof and sopcinfo and also programmed the device successfully. But after configuring the nios and...
11 years agoCould you provide some more details about your setting? Such as configuration of your clocks, of the NIOS (including used RAM for data- and for instruction-master).
Maybe as screenshots? The first things I would look on are: - clocking - resets - working RAM (in case of DDR and SoC you need to enable the FPGA->SDRAM-Bridge)
