11 years agoDownload Elf file failed
Hi, i've got another problem with running hello world on nios ii. I use Altera cyclone IV EP4CE22E22C8 in a board with a epcs flash, a sdram and a 60MHz Clock. My problem is after builduing t...
11 years agoThis is just an idea due to the minimal set of information you gave here:
-Are all resets connected correctly to the processor and are not active at the moment? -If you use just an external memory for the NIOS, does the memory run well? -Have you programmed the sof to the FPGA? With more information from your side the answer could be more precise...
