20 years agoDownload But Verify Failed
Hi All, I am using Nios Dev Board with MT48LC2M32B2 SDRAM(It is the only execute memory). When I make a software example and download it to sdram, it displays in nios IDE console: <div class='qu...
20 years agoA better way to calculate how many degree should be shifted is using the oscilloscope or logic analyzer. You can write a simple program, let dma continuously write to or read from SDRAM, from the logic analyzer, you can get how many degrees you should shift.
