20 years agoDownload But Verify Failed
Hi All, I am using Nios Dev Board with MT48LC2M32B2 SDRAM(It is the only execute memory). When I make a software example and download it to sdram, it displays in nios IDE console: <div class='qu...
20 years agoI agree that the document could be better. For example, it doesn't tell you to negate (multiply by -1) the lesser of the Read/Write Lag - but in their example they did, so I assumed that I had to negate mine. It also doesn't say what to do if one or both numbers are negative (absolute value???!)
I can say though after recompiling my design and recalculating the phase shift, I came up with -2.3ns (which ends up being -90 degrees) and it seems to all be working now.
